1080p 60fps stream is blurry with any bitrate?
zaxto
so i get very blurry/pixelated stream when moving in the game and when i stand still it goes crisp, i was streaming to youtube.
Any way to fix this, i have tried to lower my resolution and higher my bitrate but it still looks like poop.
when i was looking at stats they looked good, no missed, skipped or dropped frames.
thank you if u can help me
-zaxto
  • 2025-02-14 19-28-47.txt
...i was streaming to youtube.
YouTube tests the viewer's connection, and automatically picks a level of degrading to give to that viewer, so that it stays smooth. Slower connections (as YT determines) get worse quality.
Change the quality setting in YT's player from Auto to what you gave it (force that quality for yourself), and see if it looks better. If it does, then there's nothing more to do. You can't force others' quality.
I had the stream forced to max quality.
Its Look crisp to me on Phone
On phone it looks good but when watching on pc it gets blurry.
If it's good on *any* receiving device, then everything on the sending end is good.
That said though, a phone isn't necessarily a good test. A small screen doesn't show much.
Looks okay to me anyway, on my 17" 1920x1080 screen, forced to 1080p60 fullscreen.
...blurry/pixelated stream when moving in the game and when i stand still it goes crisp
That's just the nature of lossy video compression. You need an insane bitrate to not do that. Look at the file size from a Lossless recording and divide by the runtime...
What u mean by ”insane” bitrate, highest i tried was 25k, highest i could try is about 50k but that eats all my upload speed then, how are so many streamers on twitch at 8k but still looking better than my streams?
I just recorded a 20-second Lossless test video at 1920x1080p60. For just those 20 seconds, I got a 1.2 GiB file. (1,305,005,106 bytes) Dividing that out, with 8 bits per byte, gives 522,002,042.4 bits per second, or 522M. (522,002k)
So you have to compress it. And that compression must throw away detail. For comparison, I recorded another 20-second test with the Indistinguishable setting. That gave me 39.9 MiB. (41,862,221 bytes) Dividing that out, with 8 bits per byte, gives 16,744,888.4 bits per second, or 17M. (16,745k)
Of course, both of those are far higher than your connection can support, so you have to use far fewer bits, which means that not everything that you can see can be described accurately. In other words, *something* WILL be blurry. It's only a question of "What?" and "Will you notice?"
Are you criticizing yourself more than you criticize them? That's easy to do. I think you look okay.
There are tricks and command-line options that get into the highly technical weeds in a really big hurry, to tell the encoder just what to preserve and what to throw away, but very few people actually get into that. Maybe your favorites do?
And I believe that Twitch also has an affiliate program, that effectively amounts to "paying Twitch to make you better" or something like that. Don't know the details, as I'm not on Twitch at all, but that *is* the impression that I get from the outside. So if you're not an affiliate, it could be that you actually *are* sending them something good and they kill it.
But again, the link that you gave here, looks just fine to me. Nothing unexpected, anyway.
Because you're comparing Twitch streams, which can be unprocessed if it's within their bitrate limits, to YouTube which always uses compression. The biggest contributing factor when moving is most likely the Adaptive Quantization, which effects how the bits are distributed on the image. It's great for a more bitrate limited environment - like Twitch - since it lowers the chance of blocky or blurry visuals by pushing the bits to areas of motion, not so much for an environment like YouTube that heavily processes the video with it's own compression
A few other factors to consider is using a Multipass Mode of Two Pass (Quarter Resolution) since it'll feed much larger motion vectors to the second pass that handles bits distribution compared to the much tighter distribution that Full Resolution tries to do. This, ironically, might be causing YouTube's compression to not handle motion correctly and add to the blurriness. Also while P7 is the best Preset to use if you want High Quality, it may be resulting in some encoder lag, so I'd suggest trying P5 (P5 and P6 are visually indistingusable, so it's better to use the more performant of the two) since it's only a slight downgrade from P7 for a big boost in encoding performance
TL;DR: YouTube's compression is screwing you over, so you have to adjust what you send to YouTube so it can make better decision with what it shows on your streams
-zaxto
BRUH! I thought I was the only one having this issue! No matter what I do my live stream always looks blurry as hell. From looking at your pictures we have the same exact settings so it must be something to do with that. Were you able to find a solution?
You quoted the first post in this thread, and nothing else. Nor did you refer to anything else. (at least, not in a way that can be identified) Did you even read anything else?
There's no direct solution in here, but several good pointers and hints as to what might be happening. Have you followed them? If so, what new details did you find that aren't mentioned here yet?
I did indeed read the entire thread but only wanted to respond to the first one. I'll try all the other tips in here but I've been having this issue for months now and so far everything I've done doesn't work so hopefully something in here will. Him and I have the same exact settings so I'm inclined to believe it's something to do with one of our settings.
