OBS Python Additional Replay Buffer 0.1
Hello, I'm using this script for a long time and it works perfectly fine but I tried to get it for a friend and he keeps getting the "ModuleNotFoundError". No matter what we do, I checked everything, pip, moviepy, importlib.resources, ffmpeg etc, EVERYTHING. And it's all the same version as mine and all the folders look the same, but mine works and his doesn't. Any help?
Hello, I'm using this script for a long time and it works perfectly fine but I tried to get it for a friend and he keeps getting the "ModuleNotFoundError". No matter what we do, I checked everything, pip, moviepy, importlib.resources, ffmpeg etc, EVERYTHING. And it's all the same version as mine and all the folders look the same, but mine works and his doesn't. Any help?View attachment 112905
As the error says, Python cannot find the module called "importlib.resources." Make sure you have it. I attached my copy just in case you need it. Alternatively, you can download it here, then extract the folder (it's a subfolder in a subfolder in the zip) and put that in your Python site-packages directory instead. However, shouldn't they be installed already? I have only tested this on this version of Python.
If your files are already there, it could be a path issue. It seems to call for "importlib.resources" while the folder is called "importlib_resources" - you could try renaming it and see if that fixes it.
If that also doesn't work, my last idea would be to type "environment variables" into your Windows search, navigate to Environment Variables at the bottom right corner, click on Path, then edit, then new -> put your Python install there. That should ensure that whatever module is being called is found. Let me know if any of these fixes solved your problem.
@ibz38 this error message:
File "... Python36\lib\site-packages\imageio_ffmpeg\_utils.py", line 6, in <module> import importlib.resources
means that you have installed "imageio_ffmpeg" module v0.5.0 or newer (today it is likely v0.6.0 for Python v3.9 and newer). You likely need older version of the "imageio_ffmpeg" module.
The script ("AdditionalReplays_0_3_8_beta_2024_12_06.zip" from this post: https://obsproject.com/forum/threads/additional-replay-buffer.106619/post-666928 ) should work fine with the Python v3.6.8, moviepy==1.0.3, imageio==2.15.0, imageio-ffmpeg==0.4.9.
When you recently installed Python v3.6.8 (standard, not embeded version, and no other modules installed yet) then you may try to install required modules manually. In command line required commands may look like this:
pip install --upgrade-strategy only-if-needed imageio-ffmpeg==0.4.9
pip install --upgrade-strategy only-if-needed imageio==2.15.0
pip install --upgrade-strategy only-if-needed moviepy==1.0.3
Edit: the sequence of installation of the modules is important too, because not all modules in the Python explicitly request dependent versions, and modules installed later may unintentionally upgrade already installed modules.
@dlawton18 you are run into issue that is known bug in the original script. You forgot to specify the destination file path (folder) for the replays in the script properties. If you read this thread carefully you will find more newer version of the same script that has some bugs fixed.
@Suslik V Thanks a lot for the script. There is only one problem, there are freezes and stuttering in the first 5~ seconds after the videos are cut. After suddenly speeding up and returning to normal speed, there is no problem.
@Suslik V I solved the problem by editing the python script. However, while the cutting is occurring, the fps drops a lot in the game and cuts video slow. If anyone wants it, I can share it.
@cengo Yes, I would love to see this version. At the moment, I just have the replay length a bit longer than it should be (i.e. 15 seconds is now 20 seconds) so the first 5 seconds are laggy and redundant but the 15 seconds I needed are still there. However, this does take more storage and time if I wanted to trim it down properly. So I would like to see if a couple seconds of FPS drop is worth it
Actually the solution is much simpler. In the AMF/FFMPEG Settings under Encoder Settings in OBS, type "keyint=30"
・Display a message window that automatically closes when a shortcut key is pressed
・Extend the maximum recording time to 15 minutes
We have implemented these changes.
We also discovered a bug where code changes are not reflected in OBS unless the file name is changed. To be safe, you should rename the file whenever you replace the code.
