Advanced Scene Switcher Stopping A Stream
iRedakted
Hello All,
I've trying combing through this forum to find the answer to my question but with the newest updates, to the plugin, things don't look the same.
Essentially, I want to run some VODS that are on average a minimum of 5 hours long on my stream. Once the VOD is done I want the stream to stop. How can I do that on version 1.32.9? I've tried a few macros and timer settings but it hasn't seemed to work. Also my settings for the plugin seem "broken"? Some drop downs are labeled with the full prefix instead of whatever the setting is.
Any help would be greatly appreciated!
If you have issues with a third party plugin you should contact its dev via the Discussion section on the particular plugins' page or wherever the dev have set for this.
