Advanced Scene Switcher
I need some help to get the plugin working again
I was using it before, but reinstalled windows and since then I couldn't get the plugin to work properly
I'm using OBS 32.1.2 and Advanced Scene Switcher 1.34.2
Basically, when opening the plugin I get this error:
I was using the plugin to display to connect actions in my OBS to redeems, but with this error, that doesn't work. The option to use a twitch redeem as trigger disappeared
So far I've tried:
- Installing the plugin both via .exe installer and manually
- Installing an older version of the plugin, both via legacy and new method
- Reinstalling OBS and doing a clean install of everything
I can see the files are in the folder in the exact same path that the error message describes it
I am running OBS as admin
I'm really at a loss for what to do, so any help is appreciated
Thanks in advance
Can you please try the following:
  • Uninstall the plugin
  • Re-install the plugin, but instead of using the suggested path in the installer use:
    C:\Program Files\obs-studio
  • Launch OBS
That is assuming you have installed OBS to C:\Program Files\obs-studio of course.
Can I just ask which version of Windows and OBS you are using?
  • Launch OBS
That solved the problem! Thank you so much!
I'm using OBS 32.1.2 and Windows 11 25H2
Hello !
It would be awesome if we could hide the "Set transition to" and "Set transition duration to" options on each 'Scene Item Visibility' action. Right now, it makes the element way too large vertically, which is really impractical and cluttered when you stack a lot of them in a row.
On top of that, the plugin is becoming less and less responsive. Each action now takes more than a second to process, which wasn't the case a few months ago...
Hello !
Unfortunately, I am not sure how I would hide those additional options "effectively".
Introducing yet another checkbox "hide XY settings ... " just to hide two other checkboxes seems a bit pointless.
But I am open to suggestions!
Just to mention it:
You can collapse individual actions / conditions so they take up less space:
Regarding the performance issues you mentioned:
Can you reproduce the issue and share a corresponding OBS log file with verbose logging enabled?
Then I should be able to see which actions / conditions take an unexpected amount of time to process.
