KattPhloxworthy
Member
Add another plea for a Start All, and more importantly Stop All option.
Ideally, there should be options "per-item" option to start and/or stop when the Start/Stop Streaming button is pressed.
--Katt. =^.^=
2. when I click start streaming on OBS it ONLY goes live on one platform, i then have to manually click go live on the others on the aitu, dock, is there a way to connect it to all go live together??
- Add update question dialog
- Add Chinese translation by liangzhiiu18718
- Add Portuguese translation by Sty13
- Split expanded and advanced mode
- Fix encoder index visibility
- Fix memory leak in output dialog
For some reason multistream is crashing my obs, i uninstalled all of my other plugins and left only multistream and it won't even allow me to use obs. The app just flickers and then it says "Not Responding"
