Auto-Resize Window Capture
ChuckMo
I am trying to resize the window capture to the actual size of the window automatically. Is there anything that will help with that?
As far as I see it, this is done automatically, if you don't set any custom transform. To reset the transform, right-click the source->Transform->Reset transform or delete+recreate the source and don't use any custom transformation like manually resizing, centering, fitting, stretching and probably cropping the source.
If you are using a different game resolution than your Windows resolution, you need to do:
Right-click the source->Transform->Stretch to screen
That's it!
  • Ajustar de resolucao da captura da origem para resolucao output do stream.png
  • Edicao tela de transformacao de source com Stretch to Bounds ativo para output do stream.png
