Bioshock 1 remastered - Hepheastus area keeps crashing OBS?
OiranTavern
So, as the title suggests, I'm playing through Bioshock remastered on stream but the Hepheastus area makes my stream/OBS crash, like, it just doesn't respond anymore. I restarted stream 2 times with no improvement. The error I would see at the bottom of my obs window was regarding the encoder preset overloading asking me to modify the preset in the settings or to reduce the graphics of the game. (If you played the game, you know how little I can change.). The OG setting that I had for the encoder is the veryfast one. I attempted to change it to faster/fast, but nothing seemed to happen and it didn't help either.
I haven't had any problems with streaming Bioshock remastered before, so I'm very lost as to what to do now to fix it. I've been told that the Hepheastus area caused problems on the 360 as well, so I'm just wondering if it's just better to simply play the rest of the area off stream and to simply continue streaming it once the area is done.
OBS is updated to the latest version, and I'll attach the log files of today's stream in the thread. Same goes for the output settings I already have.
If anyone would kindly help me find a solution, I'd be super grateful. My viewers and I are really eager and impatient to meeting with Mr. Andrew Ryan!
Thank you!
  • 2024-08-22 09-56-30.txt
  • 2024-08-22 10-23-55.txt
  • 2024-08-22 11-16-22.txt
  • 2024-08-22 11-43-54.txt
  • 2024-08-22 11-47-36.txt
  • 2024-08-22 15-57-47.txt
