Deckboard
Semi-free Deckboard 3.2.0
rfbabeheer submitted a new resource:
Deckboard - Custom computer macro on Android device
Avaiable on Windows and Android
Development Status : Active
Create custom computer macro shortcuts and launch them through your device.
No more windows switching to open the folder or website, get Deckboard to simplify them and maximize your productivity. With OBS Studio and Streamlabs OBS support, take Deckboard as your personal streaming companion tool!
Features
• Custom macro button with image and label
• Unlimited macros with 4 x 3 buttons per...
rfbabeheer updated Deckboard with a new update entry:
August 2018 (version 1.2.3)
New Features
  • Bind macro keys to selected software.
  • Add argument for selected software in Run Program action.
  • Add support for steam:// protocol in Open Website action.
  • Fix OBS hotkeys input.
  • Add static release notes.
UI Changes
  • Add fullscreen button.
  • Add icons and background colors on button preview for respective actions on Create/Edit button modals.
  • Remove text shadow on shortcut label...
This is awesome :) it's basically Elgato Streamdeck but in Free (or only 2.49€, which i bought), i have currently only one issue, it doesn't Update (it downloads (it says on the bottom left "Update downloaded") but doesn't intall it (after restart it stays the same version, and when i manually start Deckboard it gives me a JavaScript Error but works fine)). Some applications like OBS and Stramlables ChatBot doesn't or start or enter Setup mode, but overall Deckboard is really awesome.
Some features i would personally like:
-Automatic detection of obs is running and automatically connect to obs
-Some feedback from buttons when pressed like switching the image or text (or both) when i mute something or start/stop the stream,
-the change of volume of multimedia application only affecting the multimedia application and not the whole system
-option for Type Text to send the text directly in the twitch chat
note: i am German so English is not my native language
September 2018 (version 1.2.5)
Twitter support (Beta)
Now you can post your tweet through Deckboard. you just need to log in and create the Post Tweet action button.
Notes: You cannot post the same tweet within 12 hours.
Write your custom extensions (Beta)
For the users who experienced in NodeJS, you can create your own button with custom function. For further information, click here....
Can someone helps me on how to use it? i download both android and windows app, it connects but it does nothing. doesn't play sound, doesn't switches scene...i guess i need some help
December 2018 (version 1.2.631)
DECKBOARD ♥ SPOTIFY
Rejoice! Spotify is now supported in Deckboard! Here are the current Spotify features available:
  • Control player playback
  • Search and play tracks from your favourite artist, albums, and playlist.
  • Automatic fetch the cover image when artist/albums/playlist selected.
New Features
  • Copy, Cut, Paste, and Delete for right click menu added.
  • Advance keyboard macro editor action added.
Can someone helps me on how to use it? i download both android and windows app, it connects but it does nothing. doesn't play sound, doesn't switches scene mybkexperience.
Hey! Got the latest version, bought PRO and it's really lovely.
Noticed that "toggle source" for OBS Studio isn't showing any source dropdown. Any way to fix this? Or is it in the works?
Thanks!
June 2019 (version 1.5.0)
New Features
Board/Button Customizations
  • Additional grid layouts
  • Button border color
  • Button shape (square, circle, and image only)
Twitch Integrations
  • Send Chat
  • Clear Chat
  • Slow Chat
  • Followers Only Chat
  • Subscribers Only Chat
  • Emote Only Chat
Bug Fixes
Multiaction Setup Fixes
  • Fix bug where action parameter value(s)...
Awesome! Uses it every day streaming. However, sometimes vetween 1 minut - 1 hour it disconnects from my pc and I need to reconnect again. How could this be?
July 2019 (Version 1.6.0)
New Features
  • Add Stream Marker action for Twitch
  • Extension repository, download and install extension easily.
  • Enable autoconnect to Streamlabs OBS socket connection.
  • Enable long-press for keypress action. Useful for something like Push-to-talk function on Discord and in-game directional movement.
  • Add IP address to OBS Studio and Streamlabs OBS configuration.
UI Tweak
  • Add executable icon inside Executable File...
July 2020 (v1.9.52)
Features
  • Add capability to move board in multi action button;
  • Add 'Toggle Filter' action for OBS Studio;
  • Add opacity input in color picker.
Bug Fixes
  • Fix the bug where 'Possible IP Addresses' modal doesn't list all IP address;
  • Fix bug for where mobile app cannot shows 'Audio Device Control' action's default icon;
  • Fix the grey circle on button's background in 'Edit Button' modal.
