Encoding Overload Issues
rs25
I've been having a bit of encoding issues as of late and want to see if there's anything on the OBS side that's responsible. I see the issue when streaming games primarily but there are moments when I haven't booted that I'll still get the overload. It's my first time posting here so if more information is needed other than the attached log, let me know!
Issues a plenty, OBS is not one of them. I could make a list of stuff but it would be too long.
It doesn't appear that there was an encoding session in that log so limited info provided.
Check & verify all of your plugins are updated for the version of OBS in play. SE failed the test.
20:43:50.829: obs-streamelements: ShowStatusBarMessage: Software update available.
Something is running on your system causing a conflict with OBS. Adobe CC comes to mind.....
01:59:03.696: Blocked loading of '\coresync_x64.dll' 12 times.
Your Scene Collection is massive, it could be causing issues. While you're troubleshooting, create a New Scene Collection & add just (1) Source, see if things improve.
Took me some time but I finally found the encoding session hidden in all those errors. It's not horrible. There's some Rendering Lag/GPU overload. Doing the above should help but may not eliminate it all.
Load reduction:
Run only (1) monitor @ high refresh rates
Media Sources, there's a ton of them & I counted at least (15) using hardware acceleration. Only (2) maybe (3) of them in your main scene should be using it, disable it for all others & save the VRAM for something else as your system has plenty of free RAM available.
Scene Collection - Streamline it, nothing is free.
See Link
01:58:20.421: Last log entry repeated for 7 more lines
01:58:20.421: [rtmp stream: 'aitum_multi_output_YouTube Output'] User stopped the stream
01:58:20.421: [rtmp stream: 'aitum_multi_output_YouTube Output'] Socket send buffer is 2097152 bytes
01:58:20.426: Output 'aitum_multi_output_YouTube Output': stopping
01:58:20.426: Output 'aitum_multi_output_YouTube Output': Total frames output: 889474
01:58:20.426: Output 'aitum_multi_output_YouTube Output': Total drawn frames: 884600 (889612 attempted)
01:58:20.426: Output 'aitum_multi_output_YouTube Output': Number of lagged frames due to rendering lag/stalls: 5012 (0.6%)
01:58:22.251: Output 'adv_stream': stopping
01:58:22.251: Output 'adv_stream': Total frames output: 1058303
01:58:22.251: Output 'adv_stream': Total drawn frames: 1053238 (1058383 attempted)
01:58:22.251: Output 'adv_stream': Number of lagged frames due to rendering lag/stalls: 5145 (0.5%)
01:58:22.251: Video stopped, number of skipped frames due to encoding lag: 5155/1058338 (0.5%)
01:58:22.254: [obs-browser: 'YT Shirt'] Error: Blocked script execution in 'about:blank' because the document's frame is sandboxed and the 'allow-scripts' permission is not set. (about:blank:0)
01:58:22.257: ==== Streaming Stop ================================================
01:58:22.332: warning: 2 frames left in the queue on closing
01:58:22.333: warning: 2 frames left in the queue on closing
01:58:22.873: Output 'Vertical Backtrack': stopping
01:58:22.873: Output 'Vertical Backtrack': Total frames output: 1058337
01:58:22.873: Output 'Vertical Backtrack': Total drawn frames: 1053227 (1058372 attempted)
01:58:22.873: Output 'Vertical Backtrack': Number of lagged frames due to rendering lag/stalls: 5145 (0.5%)
01:58:22.874: Video stopped, number of skipped frames due to encoding lag: 5354/1058370 (0.5%)
01:58:22.926: warning: 2 frames left in the queue on closing
