Bug Report External camera with OBS
liwei
Hello,Everyone,
I have a external camera connect to PC, but when I use OBS MultiPlatform 0.7.3 , I cannt get video and audio either.
This is the compare result between obs and AV/C:
Adobe Flash Media Live Encoder 3.2 => Video (OK) , Audio (OK)
OBS 0.651 => Video (OK) , Audio (Failed)
OBS MultiPlatform 0.7.3 => Video (Failed) , Audio (Failed)
Anybody know why? Thanks!
Also, you should probably update to the latest release, 0.9.1 (at the time of this writing).
Hi, Jim & dodgepong,
Thank you for your reply!
I have used 0.9.1 in Win7 32bit. it has the same problem.
camera: sony AX2000E
Woops,OBS has crashed!
That crash I think should be fixed in 0.10.0 -- at least I think that's the one I encountered.
Thank you Jim!
I have a good news.
Somebody told me that AverMedia works well in my software based on obs, I bought one, yes , it's true !
The usb card is "AverMedia DVD EZMaker7" , now both video and audio work well in 0.7.3 and 0.9.1.
