Failed to connect to server (Stream to Twitch)
Devilz
Greetings. every time I try to Stream to twitch and click (Start streaming) it gives me an error that says "Failed to connect to server". I already check yt and everything. Stream key, Bitrate, Network, etc.. I hope you can help me. Have a great day.
Are you manually setting up the Twitch connection providing the stream key or are you using the connect twitch account option instead? Have you tried connecting using both methods. If your OBS is set to connect to twitch on default, and both these setups fail. But other sites such as YT work. I would try to see if there is some kind of firewall blocking twitch.
I connected both stream key and the account. and I allowed OBS to use the network from the firewall manager. I think the problem is with Twitch servers not OBS Because I downloaded Twitch studio I had the same issue with it.
That would be weird if its a continuous problem. I would expect if their servers were down, they would fix asap and this would be just a blip. I'd still recommend to review if there are any other third party items blocking that specific connection.
So I now know the problem is not with my internet because I was able to stream from my phone without a problem. So that's a positive start. Now I know the problem is with my PC. Maybe there is a program/software I downloaded that keeps blocking me or something like that. I will try to fix it and I will tell you what happened.
