Feature Request: Color Coding Preview & Program
Jason Hunt
For studio mode, it would be helpful to have the monitor windows labeled. Typical of television studios, what's on the air is labeled PROGRAM (PRG) and the stand-by monitor is labeled PREVIEW (PVW). This would be helpful to have in the OBS control panel as well.
It would also help that these labels are color coded to correspond to the particular scene that's in each window. I've attached a mock-up to show you what it might look like.
Thank you for your consideration.
