game capture not working anymore
psylockeer
I am running OBS 31.0.2 on Nobara 41. Everything was working fine last time I recorded (2 days ago). I use the option "game capture" were I select the window of the game and that has always worked until today. I noticed I the preview on OBS was a black screen and only audio was being recorded.
I tried restarting, I tried select a different window option and now I cannot select the game window anymore.
Using "screen capture" works but since I play with HDR but record without I am missing the option to select "force HDR". Any idea why this is happening?
Here is log file
13:01:34.104: Platform: Wayland
13:01:34.104: CPU Name: AMD Ryzen 9 9900X 12-Core Processor
13:01:34.104: CPU Speed: 5564.696MHz
13:01:34.104: Physical Cores: 12, Logical Cores: 24
13:01:34.104: Physical Memory: 31186MB Total, 4659MB Free
13:01:34.104: Kernel Version: Linux 6.14.2-200.nobara.fc41.x86_64
13:01:34.104: Distribution: "Nobara Linux" 41
13:01:34.104: Desktop Environment: KDE (KDE)
13:01:34.104: Session Type: wayland
13:01:34.105: Qt Version: 6.8.2 (runtime), 6.8.2 (compiled)
13:01:34.105: Portable mode: false
13:01:34.121: OBS 31.0.2 (linux)
13:01:34.121: ---------------------------------
13:01:34.122: ---------------------------------
13:01:34.122: audio settings reset:
13:01:34.122: samples per sec: 48000
13:01:34.122: speakers: 2
13:01:34.122: max buffering: 960 milliseconds
13:01:34.122: buffering type: dynamically increasing
13:01:34.126: ---------------------------------
13:01:34.126: Initializing OpenGL...
13:01:34.126: Using EGL/Wayland
13:01:34.130: Initialized EGL 1.5
13:01:34.137: Loading up OpenGL on adapter AMD AMD Radeon RX 7900 XTX (radeonsi, navi31, LLVM 19.1.7, DRM 3.61, 6.14.2-200.nobara.fc41.x86_64)
13:01:34.137: OpenGL loaded successfully, version 4.6 (Core Profile) Mesa 25.0.3, shading language 4.60
13:01:34.171: ---------------------------------
13:01:34.172: video settings reset:
13:01:34.172: base resolution: 2560x1440
13:01:34.172: output resolution: 2560x1440
13:01:34.172: downscale filter: Bicubic
13:01:34.172: fps: 60/1
13:01:34.172: format: P010
13:01:34.172: YUV mode: Rec. 2100 (PQ)/Full
13:01:34.172: NV12 texture support not available
13:01:34.172: P010 texture support enabled
13:01:34.173: Audio monitoring device:
13:01:34.173: name: Family 17h/19h/1ah HD Audio Controller Analog Stereo
13:01:34.173: id: alsa_output.pci-0000_75_00.6.analog-stereo
13:01:34.174: ---------------------------------
13:01:34.189: Failed to load 'en-GB' text for module: 'aitum-multistream.so'
13:01:34.189: [Aitum-Multistream] loaded version 1.0.7
13:01:34.194: [Aitum Multistream] Loaded configuration file
13:01:34.207: Failed to load 'en-US' text for module: 'decklink-captions.so'
13:01:34.218: Failed to load 'en-US' text for module: 'decklink-output-ui.so'
13:01:34.231: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
13:01:34.231: Failed to initialize module 'decklink.so'
13:01:34.246: Failed to load 'en-GB' text for module: 'distroav.so'
13:01:34.246: [DistroAV] obs_module_load: you can haz DistroAV (Version 6.0.0)
13:01:34.246: [DistroAV] obs_module_load: Qt Version: 6.8.2 (runtime), 6.8.0 (compiled)
13:01:34.247: [DistroAV] load_ndilib: Found '/usr/lib64/libndi.so.5'; attempting to load NDI library...
13:01:34.248: [DistroAV] load_ndilib: NDI library loaded successfully
13:01:34.248: [DistroAV] load_ndilib: NDIlib_v5_load found
13:01:34.248: [DistroAV] obs_module_load: NDI library initialized successfully ('NDI SDK LINUX 12:52:02 Feb 16 2024 5.6.1')
13:01:34.429: Failed to load 'en-GB' text for module: 'linux-pipewire-audio.so'
13:01:34.449: [pipewire] Available capture sources:
13:01:34.449: [pipewire] - Monitor source
13:01:34.449: [pipewire] - Window source
13:01:34.494: Failed to load 'en-GB' text for module: 'linux-vkcapture.so'
13:01:34.494: [linux-vkcapture] plugin loaded successfully (version 1.5.1)
13:01:34.508: Failed to load 'en-GB' text for module: 'media-playlist-source.so'
13:01:34.508: [media-playlist-source] plugin loaded successfully (version 0.0.7)
13:01:34.579: Failed to load 'en-GB' text for module: 'obs-backgroundremoval.so'
13:01:34.579: [obs-backgroundremoval] Plugin loaded successfully (version 1.1.13)
13:01:34.579: [obs-backgroundremoval] Failed to open config file /home/pier/.config/obs-studio/plugin_config/obs-backgroundremoval/config.ini
13:01:34.864: [obs-backgroundremoval] Latest release is
13:01:34.880: [obs-browser]: Version 2.24.6
13:01:34.880: [obs-browser]: CEF Version 127.0.6533.100 (runtime), 127.3.4+ge9e2e14+chromium-127.0.6533.100 (compiled)
13:01:34.964: VAAPI: API version 1.22
13:01:34.965: FFmpeg VAAPI H264 encoding supported
13:01:34.967: FFmpeg VAAPI AV1 encoding supported
13:01:34.969: FFmpeg VAAPI HEVC encoding supported
13:01:35.008: os_dlopen(libnvidia-encode.so.1->libnvidia-encode.so.1): libnvidia-encode.so.1: cannot open shared object file: No such file or directory
13:01:35.008:
13:01:35.008: NVENC not supported
13:01:35.008: Failed to initialize module 'obs-nvenc.so'
13:01:35.076: [obs-vaapi] version: undefined, gst-runtime: 1.24.11
13:01:35.081: [obs-vaapi] found vah265enc
13:01:35.081: [obs-vaapi] found vaav1enc
13:01:35.081: [obs-vaapi] found vah264enc
13:01:35.081: [obs-vaapi] found varenderD129h265enc
13:01:35.081: [obs-vaapi] found varenderD129h264enc
13:01:35.135: [obs-websocket] [obs_module_load] you can haz websockets (Version: 5.5.5 | RPC Version: 1)
13:01:35.135: [obs-websocket] [obs_module_load] Qt version (compile-time): 6.8.2 | Qt version (run-time): 6.8.2
13:01:35.135: [obs-websocket] [obs_module_load] Linked ASIO Version: 103002
13:01:35.135: DEPRECATION: obs_frontend_get_global_config is deprecated. Read from global or user configuration explicitly instead.
13:01:35.137: [obs-websocket] [obs_module_load] Module loaded.
13:01:35.177: Failed to load 'en-GB' text for module: 'source-record.so'
13:01:35.177: [Source Record] loaded version 0.4.4
13:01:35.205: Failed to load 'en-GB' text for module: 'vertical-canvas.so'
13:01:35.205: [Vertical Canvas] loaded version 1.5.2
13:01:35.205: ---------------------------------
13:01:35.205: Loaded Modules:
13:01:35.205: vertical-canvas.so
13:01:35.205: text-freetype2.so
13:01:35.205: source-record.so
13:01:35.205: rtmp-services.so
13:01:35.205: obs-x264.so
13:01:35.205: obs-websocket.so
13:01:35.205: obs-webrtc.so
13:01:35.205: obs-vst.so
13:01:35.205: obs-vaapi.so
13:01:35.205: obs-transitions.so
13:01:35.205: obs-qsv11.so
13:01:35.205: obs-outputs.so
13:01:35.205: obs-libfdk.so
13:01:35.205: obs-filters.so
13:01:35.205: obs-ffmpeg.so
13:01:35.205: obs-browser.so
13:01:35.205: obs-backgroundremoval.so
13:01:35.205: media-playlist-source.so
13:01:35.205: linux-vkcapture.so
13:01:35.205: linux-v4l2.so
13:01:35.205: linux-pulseaudio.so
13:01:35.205: linux-pipewire.so
13:01:35.205: linux-pipewire-audio.so
13:01:35.205: linux-jack.so
13:01:35.205: linux-capture.so
13:01:35.205: linux-alsa.so
13:01:35.205: image-source.so
13:01:35.205: frontend-tools.so
13:01:35.205: distroav.so
13:01:35.205: decklink-output-ui.so
13:01:35.205: decklink-captions.so
13:01:35.205: aitum-multistream.so
13:01:35.205: [Vertical Canvas] Loaded configuration file
13:01:35.215: QLayout: Attempting to add QLayout "" to CanvasDock "contextContainer", which already has a layout
13:01:35.219: os_dlopen(obs->obs.so): obs.so: cannot open shared object file: No such file or directory
13:01:35.219:
13:01:35.219: [DistroAV] +obs_module_post_load()
13:01:35.219: [DistroAV] +updateCheckStart(userRequestCallback=nullptr)
13:01:35.219: [DistroAV] -updateCheckStart(userRequestCallback=nullptr)
13:01:35.219: [DistroAV] -obs_module_post_load()
13:01:35.219: ---------------------------------
13:01:35.219: Available Encoders:
13:01:35.219: Video Encoders:
13:01:35.219: - ffmpeg_openh264 (OpenH264)
13:01:35.219: - ffmpeg_svt_av1 (SVT-AV1)
13:01:35.219: - ffmpeg_aom_av1 (AOM AV1)
13:01:35.219: - ffmpeg_vaapi_tex (FFmpeg VAAPI H.264)
13:01:35.219: - av1_ffmpeg_vaapi_tex (FFmpeg VAAPI AV1)
13:01:35.219: - hevc_ffmpeg_vaapi_tex (FFmpeg VAAPI HEVC)
13:01:35.223: - obs-va-vah265enc (VAAPI H.265 on Navi 31 [Radeon RX 7900 XT/7900 XTX/7900 GRE/7900M])
13:01:35.226: - obs-va-vaav1enc (VAAPI AV1 on Navi 31 [Radeon RX 7900 XT/7900 XTX/7900 GRE/7900M])
13:01:35.229: - obs-va-vah264enc (VAAPI H.264 on Navi 31 [Radeon RX 7900 XT/7900 XTX/7900 GRE/7900M])
13:01:35.232: - obs-va-varenderD129h265enc (VAAPI H.265 on Granite Ridge [Radeon Graphics])
13:01:35.235: - obs-va-varenderD129h264enc (VAAPI H.264 on Granite Ridge [Radeon Graphics])
13:01:35.235: - obs_x264 (x264)
13:01:35.235: Audio Encoders:
13:01:35.235: - ffmpeg_aac (FFmpeg AAC)
13:01:35.235: - ffmpeg_opus (FFmpeg Opus)
13:01:35.235: - ffmpeg_pcm_s16le (FFmpeg PCM (16-bit))
13:01:35.235: - ffmpeg_pcm_s24le (FFmpeg PCM (24-bit))
13:01:35.235: - ffmpeg_pcm_f32le (FFmpeg PCM (32-bit float))
13:01:35.235: - ffmpeg_alac (FFmpeg ALAC (24-bit))
13:01:35.235: - ffmpeg_flac (FFmpeg FLAC (16-bit))
13:01:35.235: - libfdk_aac (libfdk AAC)
13:01:35.235: ==== Startup complete ===============================================
13:01:35.275: All scene data cleared
13:01:35.275: ------------------------------------------------
13:01:35.277: pulse-input: Server name: 'PulseAudio (on PipeWire 1.2.7) 15.0.0'
13:01:35.277: pulse-input: Audio format: s32le, 48000 Hz, 2 channels
13:01:35.277: pulse-input: Started recording from 'alsa_output.pci-0000_75_00.6.analog-stereo.monitor'
13:01:35.277: [Loaded global audio device]: 'Desktop Audio'
13:01:35.277: pulse-input: Audio format: s24le, 48000 Hz, 1 channels
13:01:35.277: pulse-input: Sample format s24le not supported by OBS,using float32le instead for recording
13:01:35.277: pulse-input: Started recording from 'alsa_input.usb-DCMT_Technology_USB_Condenser_Microphone_214b206000000178-00.pro-input-0'
13:01:35.277: [Loaded global audio device]: 'Mic/Aux'
13:01:35.279: ext_screencopy_manager_v1 not available
13:01:35.279: PipeWire initialized
13:01:35.280: Switched to scene 'Game'
13:01:35.280: ------------------------------------------------
13:01:35.280: Loaded scenes:
13:01:35.280: - scene 'Vertical Scene':
13:01:35.280: - scene 'Game':
13:01:35.280: - source: 'Game Capture' (vkcapture-source)
13:01:35.280: - source: 'Screen Capture (PipeWire)' (pipewire-screen-capture-source)
13:01:35.335: [DistroAV] +main_output_init()
13:01:35.335: [DistroAV] +main_output_deinit()
13:01:35.335: [DistroAV] main_output_deinit: NDI main output is not initialized
13:01:35.335: [DistroAV] -main_output_deinit()
13:01:35.335: [DistroAV] main_output_init: creating NDI main output 'OBS'
13:01:35.335: [DistroAV] +ndi_output_getdefaults()
13:01:35.335: [DistroAV] -ndi_output_getdefaults()
13:01:35.335: [DistroAV] +ndi_output_create(name='OBS', groups='', ...)
13:01:35.335: [DistroAV] ndi_output_update(name='OBS', groups='', ...)
13:01:35.335: [DistroAV] -ndi_output_create(name='OBS', groups='', ...)
13:01:35.335: [DistroAV] main_output_init: successfully created NDI main output 'OBS'
13:01:35.335: [DistroAV] -main_output_init()
13:01:35.335: [DistroAV] +preview_output_init()
13:01:35.335: [DistroAV] +preview_output_deinit()
13:01:35.335: [DistroAV] preview_output_deinit: NDI preview output is not initialized
13:01:35.335: [DistroAV] -preview_output_deinit()
13:01:35.335: [DistroAV] preview_output_init: creating NDI preview output 'OBS Preview'
13:01:35.335: [DistroAV] +ndi_output_create(name='OBS Preview', groups='', ...)
13:01:35.335: [DistroAV] ndi_output_update(name='OBS Preview', groups='', ...)
13:01:35.335: [DistroAV] -ndi_output_create(name='OBS Preview', groups='', ...)
13:01:35.335: [DistroAV] preview_output_init: successfully created NDI preview output 'OBS Preview'
13:01:35.335: [DistroAV] -preview_output_init()
13:01:35.346: [pipewire] Screencast session created
13:01:35.384: [pipewire] Asking for monitor and window
13:01:35.504: [DistroAV] RemoteTextThread: HTTP request failed. `{ "curlCode":{ "code":22, "text":"HTTP response code said error" }, "error":"The requested URL returned error: 412" }`
13:01:35.504: [DistroAV] onCheckForUpdateNetworkFinish(httpStatusCode=412, responseData=..., errorData=`{ "curlCode":{ "code":22, "text":"HTTP response code said error" }, "error":"The requested URL returned error: 412" }`, userRequestCallback=nullptr)
13:01:35.504: [DistroAV] onCheckForUpdateNetworkFinish: Error! httpStatusCode=412, errorData=`{ "curlCode":{ "code":22, "text":"HTTP response code said error" }, "error":"The requested URL returned error: 412" }`; ignoring response
13:01:36.021: adding 42 milliseconds of audio buffering, total audio buffering is now 42 milliseconds (source: Desktop Audio)
13:01:36.021:
Here is log file
13:01:35.008:
13:01:35.219:
13:01:36.021:
I am having the same issue with Nobara 41. The "Game Capture" source is not working properly. It displays a black screen if a new game capture source is created and a black screen in scenes with a game capture source built prior to the 31.0.2 update. Unfortunately, the reply regarding github was not helpful due to these plugins already being installed. Any help/fix regarding this matter would be greatly appreciated. Thank you.
I have the exact same problem also on Nobara 41. This issue must have been caused by an update in the last 3 weeks. Everything worked the last time I used OBS. I was not able to find any solution yet.
I'm having the same issue too on Linux Mint. I was streaming earlier today and it worked fine, but then OBS crashed. Now, I'm getting the black screen issue with it just showing my mouse and a tiny box in the corner
