Question / Help How to get obs studio to find my graphis card encoder(and need fix on choppyness)
ZoruaBitGamer
so i have an amd graphics card and all my bideos are choppy and laggy im not shure if its the encoder or not. my amd incorder if i have one is not being showed and saying i make youtube videos i kind of need to have this choppyness gone. i am also wondering what settings will mostlikely remove the choppyness
nvm found it
19:43:25.697: CPU Name: AMD FX(tm)-4300 Quad-Core Processor
19:43:25.697: CPU Speed: 3817MHz
19:43:25.697: Physical Cores: 2, Logical Cores: 4
19:43:25.697: Physical Memory: 8175MB Total, 2476MB Free
19:43:25.697: Windows Version: 10.0 Build 17134 (revision: 228; 64-bit)
19:43:25.697: Running as administrator: false
19:43:25.697: Aero is Enabled (Aero is always on for windows 8 and above)
19:43:25.698: Windows 10 Gaming Features:
19:43:25.698: Game DVR: On
19:43:25.699: Sec. Software Status:
19:43:25.701: Windows Defender Antivirus: enabled (AV)
19:43:25.701: Windows Firewall: enabled (FW)
19:43:25.702: Windows Defender Antivirus: enabled (ASW)
19:43:25.702: Browser Hardware Acceleration: true
19:43:25.702: Portable mode: false
19:43:25.911: OBS 22.0.1 (64-bit, windows)
19:43:25.911: ---------------------------------
19:43:25.911: audio settings reset:
19:43:25.911: samples per sec: 44100
19:43:25.911: speakers: 2
19:43:25.913: ---------------------------------
19:43:25.913: Initializing D3D11...
19:43:25.913: Available Video Adapters:
19:43:25.915: Adapter 1: AMD Radeon R7 200 Series
19:43:25.915: Dedicated VRAM: 2127134720
19:43:25.915: Shared VRAM: 4286179328
19:43:25.915: output 1: pos={0, 0}, size={1920, 1080}, attached=true
19:43:25.915: output 2: pos={1920, 0}, size={1280, 1024}, attached=true
19:43:25.918: Loading up D3D11 on adapter AMD Radeon R7 200 Series (0)
19:43:25.947: D3D11 loaded successfully, feature level used: 45056
19:43:27.124: ---------------------------------
19:43:27.124: video settings reset:
19:43:27.124: base resolution: 1920x1080
19:43:27.124: output resolution: 852x480
19:43:27.124: downscale filter: Bicubic
19:43:27.124: fps: 60/1
19:43:27.124: format: NV12
19:43:27.124: YUV mode: 601/Partial
19:43:27.126: Audio monitoring device:
19:43:27.126: name: Default
19:43:27.126: id: default
19:43:27.126: ---------------------------------
19:43:27.128: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
19:43:27.130: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
19:43:28.049: [AMF] The AMF Runtime is very old and unsupported, consider updating your drivers.
19:43:28.049: [AMF] Version 2.4.2 loaded (Compiled: 1.4.7.0, Runtime: 1.4.4.0, Library: 1;4;4;0;17.30.1091.1011;201709221648;CL#1462378).
19:43:28.339: [AMF] [Capability Manager] Testing Direct3D 11 Adapter 'AMD Radeon R7 200 Series (VEN_1002/DEV_6613/SUB_72401682/REV_0000)':
19:43:28.339: H264/AVC: Not Supported
19:43:28.339: H265/HEVC: Not Supported
19:43:28.339:
19:43:28.564: [AMF] [Capability Manager] Testing Direct3D 9 Adapter 'AMD Radeon R7 200 Series [\\.\DISPLAY1] (VEN_1002/DEV_6613/SUB_72401682/REV_0000)':
19:43:28.564: H264/AVC: Not Supported
19:43:28.564: H265/HEVC: Not Supported
19:43:28.564:
19:43:28.564: [AMF] [H264/AVC] Not supported by any GPU, disabling...
19:43:28.564: [AMF] [H265/HEVC] Not supported by any GPU, disabling...
19:43:28.633: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
19:43:28.634: LoadLibrary failed for '../../obs-plugins/64bit/libEGL.dll': The specified procedure could not be found.
19:43:28.634: (127)
19:43:28.634: Module '../../obs-plugins/64bit/libEGL.dll' not loaded
19:43:28.635: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
19:43:28.639: [obs-browser]: Version 2.1.2
19:43:28.658: LoadLibrary failed for 'nvEncodeAPI64.dll': The specified module could not be found.
19:43:28.658: (126)
19:43:29.933: Couldn't find VLC installation, VLC video source disabled
19:43:29.966: No blackmagic support
19:43:30.012: ---------------------------------
19:43:30.012: Loaded Modules:
19:43:30.012: win-wasapi.dll
19:43:30.012: win-mf.dll
19:43:30.012: win-dshow.dll
19:43:30.012: win-decklink.dll
19:43:30.012: win-capture.dll
19:43:30.012: vlc-video.dll
19:43:30.012: text-freetype2.dll
19:43:30.012: rtmp-services.dll
19:43:30.012: obs-x264.dll
19:43:30.012: obs-vst.dll
19:43:30.012: obs-transitions.dll
19:43:30.012: obs-text.dll
19:43:30.012: obs-qsv11.dll
19:43:30.012: obs-outputs.dll
19:43:30.012: obs-filters.dll
19:43:30.012: obs-ffmpeg.dll
19:43:30.012: obs-browser.dll
19:43:30.012: image-source.dll
19:43:30.012: frontend-tools.dll
19:43:30.012: enc-amf.dll
19:43:30.012: coreaudio-encoder.dll
19:43:30.013: ==== Startup complete ===============================================
19:43:30.014: Service '' not found
19:43:30.020: All scene data cleared
19:43:30.020: ------------------------------------------------
19:43:30.159: WASAPI: Device 'Speakers (High Definition Audio Device)' initialized
19:43:30.294: WASAPI: Device 'Microphone (High Definition Audio Device)' initialized
19:43:30.331: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
19:43:31.022: Switched to scene 'Scene'
19:43:31.025: ------------------------------------------------
19:43:31.025: Loaded scenes:
19:43:31.025: - scene 'Scene':
19:43:31.025: - source: 'Game Capture' (game_capture)
19:43:31.118: CalculateFileHash: Failed to open file 'C:\Users\zoroa\AppData\Roaming\obs-studio\updates\whatsnew.json':
19:45:40.472: adding 23 milliseconds of audio buffering, total audio buffering is now 69 milliseconds
still not showing
21:14:04.623: CPU Name: AMD FX(tm)-4300 Quad-Core Processor
21:14:04.623: CPU Speed: 3817MHz
21:14:04.623: Physical Cores: 2, Logical Cores: 4
21:14:04.623: Physical Memory: 8175MB Total, 2752MB Free
21:14:04.623: Windows Version: 10.0 Build 17134 (revision: 228; 64-bit)
21:14:04.623: Running as administrator: false
21:14:04.623: Aero is Enabled (Aero is always on for windows 8 and above)
21:14:04.623: Windows 10 Gaming Features:
21:14:04.623: Game DVR: On
21:14:04.625: Sec. Software Status:
21:14:04.628: Windows Defender Antivirus: enabled (AV)
21:14:04.628: Windows Firewall: enabled (FW)
21:14:04.629: Windows Defender Antivirus: enabled (ASW)
21:14:04.629: Browser Hardware Acceleration: true
21:14:04.629: Portable mode: false
21:14:04.991: OBS 22.0.1 (64-bit, windows)
21:14:04.991: ---------------------------------
21:14:05.059: ---------------------------------
21:14:05.059: audio settings reset:
21:14:05.059: samples per sec: 44100
21:14:05.059: speakers: 2
21:14:05.085: ---------------------------------
21:14:05.085: Initializing D3D11...
21:14:05.085: Available Video Adapters:
21:14:05.090: Adapter 1: AMD Radeon R7 200 Series
21:14:05.090: Dedicated VRAM: 2127069184
21:14:05.090: Shared VRAM: 4286179328
21:14:05.090: output 1: pos={0, 0}, size={1920, 1080}, attached=true
21:14:05.090: output 2: pos={1920, 0}, size={1280, 1024}, attached=true
21:14:05.095: Loading up D3D11 on adapter AMD Radeon R7 200 Series (0)
21:14:05.122: D3D11 loaded successfully, feature level used: 45056
21:14:06.693: ---------------------------------
21:14:06.693: video settings reset:
21:14:06.693: base resolution: 1920x1080
21:14:06.693: output resolution: 1280x720
21:14:06.693: downscale filter: Bicubic
21:14:06.693: fps: 30/1
21:14:06.693: format: NV12
21:14:06.693: YUV mode: 601/Partial
21:14:06.698: Audio monitoring device:
21:14:06.698: name: Default
21:14:06.698: id: default
21:14:06.699: ---------------------------------
21:14:06.946: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
21:14:06.958: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
21:14:07.926: [AMF] Version 2.4.2 loaded (Compiled: 1.4.7.0, Runtime: 1.4.7.0, Library: 1;4;7;0;18.10;201805161434;CL#1555789).
21:14:08.298: [AMF] [Capability Manager] Testing Direct3D 11 Adapter 'AMD Radeon R7 200 Series (VEN_1002/DEV_6613/SUB_72401682/REV_0000)':
21:14:08.298: H264/AVC: Not Supported
21:14:08.298: H265/HEVC: Not Supported
21:14:08.298:
21:14:08.562: [AMF] [Capability Manager] Testing Direct3D 9 Adapter 'AMD Radeon R7 200 Series [\\.\DISPLAY4] (VEN_1002/DEV_6613/SUB_72401682/REV_0000)':
21:14:08.562: H264/AVC: Not Supported
21:14:08.562: H265/HEVC: Not Supported
21:14:08.562:
21:14:08.562: [AMF] [H264/AVC] Not supported by any GPU, disabling...
21:14:08.562: [AMF] [H265/HEVC] Not supported by any GPU, disabling...
21:14:09.039: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
21:14:09.079: LoadLibrary failed for '../../obs-plugins/64bit/libEGL.dll': The specified procedure could not be found.
21:14:09.079: (127)
21:14:09.080: Module '../../obs-plugins/64bit/libEGL.dll' not loaded
21:14:09.136: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
21:14:09.241: [obs-browser]: Version 2.1.2
21:14:09.508: LoadLibrary failed for 'nvEncodeAPI64.dll': The specified module could not be found.
21:14:09.508: (126)
21:14:10.979: Couldn't find VLC installation, VLC video source disabled
21:14:11.065: No blackmagic support
21:14:11.180: ---------------------------------
21:14:11.180: Loaded Modules:
21:14:11.181: win-wasapi.dll
21:14:11.181: win-mf.dll
21:14:11.181: win-ivcam.dll
21:14:11.181: win-dshow.dll
21:14:11.181: win-decklink.dll
21:14:11.181: win-capture.dll
21:14:11.181: vlc-video.dll
21:14:11.181: text-freetype2.dll
21:14:11.181: rtmp-services.dll
21:14:11.181: obs-x264.dll
21:14:11.181: obs-vst.dll
21:14:11.181: obs-transitions.dll
21:14:11.181: obs-text.dll
21:14:11.181: obs-qsv11.dll
21:14:11.181: obs-outputs.dll
21:14:11.181: obs-filters.dll
21:14:11.181: obs-ffmpeg.dll
21:14:11.181: obs-browser.dll
21:14:11.181: image-source.dll
21:14:11.181: frontend-tools.dll
21:14:11.181: enc-amf.dll
21:14:11.181: coreaudio-encoder.dll
21:14:11.181: ---------------------------------
21:14:11.181: ==== Startup complete ===============================================
21:14:11.182: Service '' not found
21:14:11.195: No scene file found, creating default scene
21:14:11.196: All scene data cleared
21:14:11.196: ------------------------------------------------
21:14:11.279: WASAPI: Device 'Speakers (High Definition Audio Device)' initialized
21:14:11.355: WASAPI: Device 'Microphone (High Definition Audio Device)' initialized
21:14:11.378: Switched to scene 'Scene'
21:14:11.378: Failed to glob scene collections
21:14:11.379: CalculateFileHash: Failed to open file 'C:\Users\zoroa\AppData\Roaming\obs-studio\updates\manifest.json':
21:14:11.405: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
21:14:22.811:
21:14:22.811: ==== Auto-config wizard testing commencing ======
21:14:22.833: ---------------------------------
21:14:22.833: video settings reset:
21:14:22.833: base resolution: 1920x1080
21:14:22.833: output resolution: 852x480
21:14:22.833: downscale filter: Bicubic
21:14:22.833: fps: 60/1
21:14:22.833: format: NV12
21:14:22.833: YUV mode: 601/Partial
21:14:22.837: ---------------------------------
21:14:22.837: [x264 encoder: 'test_x264'] preset: veryfast
21:14:22.837: [x264 encoder: 'test_x264'] profile: high
21:14:22.837: [x264 encoder: 'test_x264'] settings:
21:14:22.837: rate_control: CRF
21:14:22.837: bitrate: 0
21:14:22.837: buffer size: 0
21:14:22.837: crf: 20
21:14:22.837: fps_num: 60
21:14:22.837: fps_den: 1
21:14:22.837: width: 852
21:14:22.837: height: 480
21:14:22.837: keyint: 250
21:14:22.837:
21:14:22.847: ---------------------------------
21:14:22.847: [FFmpeg aac encoder: 'test_aac'] bitrate: 32, channels: 2, channel_layout: 3
21:14:22.847:
21:14:27.850: Output 'null': stopping
21:14:27.850: Output 'null': Total frames output: 276
21:14:27.850: Output 'null': Total drawn frames: 297 (300 attempted)
21:14:27.850: Output 'null': Number of lagged frames due to rendering lag/stalls: 3 (1.0%)
21:14:27.889: ---------------------------------
21:14:27.889: video settings reset:
21:14:27.889: base resolution: 1920x1080
21:14:27.889: output resolution: 1280x720
21:14:27.889: downscale filter: Bicubic
21:14:27.889: fps: 30/1
21:14:27.889: format: NV12
21:14:27.889: YUV mode: 601/Partial
21:14:41.558: ---------------------------------
21:14:41.558: video settings reset:
21:14:41.558: base resolution: 1920x1080
21:14:41.558: output resolution: 852x480
21:14:41.558: downscale filter: Bicubic
21:14:41.558: fps: 60/1
21:14:41.558: format: NV12
21:14:41.558: YUV mode: 601/Partial
21:14:41.560: ---------------------------------
21:14:41.560: [x264 encoder: 'test_x264'] preset: veryfast
21:14:41.560: [x264 encoder: 'test_x264'] profile: high
21:14:41.560: [x264 encoder: 'test_x264'] settings:
21:14:41.560: rate_control: CRF
21:14:41.560: bitrate: 0
21:14:41.560: buffer size: 0
21:14:41.560: crf: 20
21:14:41.560: fps_num: 60
21:14:41.560: fps_den: 1
21:14:41.560: width: 852
21:14:41.560: height: 480
21:14:41.560: keyint: 250
21:14:41.560:
21:14:41.569: ---------------------------------
21:14:41.570: [FFmpeg aac encoder: 'test_aac'] bitrate: 32, channels: 2, channel_layout: 3
21:14:41.570:
21:14:46.573: Output 'null': stopping
21:14:46.573: Output 'null': Total frames output: 271
21:14:46.573: Output 'null': Total drawn frames: 297 (300 attempted)
21:14:46.573: Output 'null': Number of lagged frames due to rendering lag/stalls: 3 (1.0%)
21:14:46.573: Video stopped, number of skipped frames due to encoding lag: 14/296 (4.7%)
21:14:46.629: ---------------------------------
21:14:46.629: video settings reset:
21:14:46.629: base resolution: 1920x1080
21:14:46.629: output resolution: 1280x720
21:14:46.629: downscale filter: Bicubic
21:14:46.629: fps: 30/1
21:14:46.629: format: NV12
21:14:46.629: YUV mode: 601/Partial
21:27:07.298: ---------------------------------
21:27:07.298: video settings reset:
21:27:07.298: base resolution: 1920x1080
21:27:07.298: output resolution: 852x480
21:27:07.298: downscale filter: Bicubic
21:27:07.298: fps: 60/1
21:27:07.298: format: NV12
21:27:07.298: YUV mode: 601/Partial
21:27:07.326:
21:27:07.326: ==== Auto-config wizard testing stopping ========
21:27:07.332: CalculateFileHash: Failed to open file 'C:\Users\zoroa\AppData\Roaming\obs-studio\updates\whatsnew.json':
this is now resolved by my friend... while im still wondering how to get the gpu to record i cleard out my desktop and now its not laggy
