My stream keeps disconnecting can someone help me
ShawneFicklen
i have a high endish pc if you need specs or anymore info let me know...
The stream will disconect after like 10 or 30 mins of streaming and i cant figure out why, someone who understands the log file can you let me know...
Could you post the whole log file
Try checking with Twitch Inspector during your next stream to see what the ingest server sees
just a couple of past ones from earlier i will do more streams to test, Thank you for assisting me.
Your log (which you should review/scan) shows bandwidth issues
The OBS log can NOT see what else is going on with your PC, nor your local network. Make sure your PC, or other devices on your LAN, aren't consuming upload bandwidth that isn't available. IF your Internet connection is wireless (cellular, etc), then other neighborhood users may be contributing to WAN congestion.
If you do real-time network traffic monitoring at your WAN connection, and confirm NOTHING else is using your Internet connection, and you are still seeing such bandwidth fluctuation/contention, then likely you'll need to work with your ISP. A high-end PC is meaningless in this context if your upload bandwidth is limited (or you have competing network traffic from your PC)
It definitely looks like an ISP issue, the latest log shows when you get disconnected you're also unable to reconnect as if your connection is down or heavily lagging. Could also be a router issue if it's dying under heavy load or something.
I am having the same issue, sometimes I can stream for hours, and sometimes it's just 15 minutes. Everything disconnects out of nowhere. ISP says the connection and signals are strong. Here is my recent log.
Hello I am having the same issue as of currently I am having my stream randomly disconnect somedays its fine no disconnects other days it disconnects once then never again after sometimes 20 mins sometimes an hour not really sure what's going on when I contacted the isp they say everything looks fine we have added the 2.4ghz line and 5ghz to lower traffic while I am still connected to lan on my pc we opened up the ports that twitch likes to use for streaming and I have a support call with the level 2 tech in the morning. The isp I am using is race communications I have their gigabit fiber internet I never had disconnection problems while using xfinity recently for the past year so not sure why all of a sudden this is happening can anyone help? here is my logs for the most recent disconnected stream please reply with help <3
