Question / Help NDI Output Settings Not Showing Up Under Tools In OBS
dj2mauro
I am new to OBS and streaming. I have recently downloaded OBS and learned about NDI for streaming off of one computer and using the other computer for the bulk of my processing. I recently installed the latest version of OBS with no problems. I then installed the 4.7.1 NDI with the 4.0+ Runtime software as well. No issues with that install either. I have reset my computer and open and closed OBS multiple times and I still am not seeing the NDI Output Settings option come up for me under Tools in OBS. The other laptop I am using that I want to stream off of has successfully recognized the NDI Output Settings option in OBS with no issues. I installed everything the same way. Does anybody have any ideas? Thank you in advanced.
The computer having issues specs:
Macbook 13" 2010
OS X Sierra 10.12.6
4GB
Computer Specs of Successful NDI:
Macbook 13" 2012
OS X Mojave 10.14.1
4GB
Here is my log file i believe:
OBS 24.0.6 (mac) log file uploaded at 2020-04-07, 18:32:31
18:30:33.926: CPU Name: Intel(R) Core(TM)2 Duo CPU P8600 @ 2.40GHz
18:30:33.926: CPU Speed: 2400MHz
18:30:33.926: Physical Cores: 2, Logical Cores: 2
18:30:33.926: Physical Memory: 4096MB Total
18:30:33.926: OS Name: Mac OS X (NSMACHOperatingSystem)
18:30:33.926: OS Version: Version 10.12.6 (Build 16G29)
18:30:33.926: Kernel Version: 16.7.0
18:30:34.092: hotkeys-cocoa: Using layout 'com.apple.keylayout.US'
18:30:34.132: Portable mode: false
18:30:35.402: OBS 24.0.6 (mac)
18:30:35.402: ---------------------------------
18:30:35.420: ---------------------------------
18:30:35.420: audio settings reset:
18:30:35.420: samples per sec: 44100
18:30:35.420: speakers: 2
18:30:35.827: ---------------------------------
18:30:35.827: Initializing OpenGL...
18:30:35.905: Loading up OpenGL on adapter NVIDIA Corporation NVIDIA GeForce 320M OpenGL Engine
18:30:35.905: OpenGL loaded successfully, version 3.3 NVIDIA-10.2.37 310.90.10.05b54, shading language 3.30
18:30:36.229: ---------------------------------
18:30:36.229: video settings reset:
18:30:36.229: base resolution: 1280x800
18:30:36.229: output resolution: 1024x640
18:30:36.229: downscale filter: Bicubic
18:30:36.229: fps: 30/1
18:30:36.229: format: NV12
18:30:36.229: YUV mode: 601/Partial
18:30:36.229: NV12 texture support not available
18:30:36.233: Audio monitoring device:
18:30:36.233: name: Default
18:30:36.233: id: default
18:30:36.233: ---------------------------------
18:30:36.296: os_dlopen(/Applications/OBS.app/Contents/Plugins/advanced-scene-switcher-old.so->/Applications/OBS.app/Contents/Plugins/advanced-scene-switcher-old.so): dlopen(/Applications/OBS.app/Contents/Plugins/advanced-scene-switcher-old.so, 257): Library not loaded: @executable_path/../../Resources/bin/QtWidgets
18:30:36.296: Referenced from: /Applications/OBS.app/Contents/Plugins/advanced-scene-switcher-old.so
18:30:36.296: Reason: image not found
18:30:36.296:
18:30:36.297: Module '/Applications/OBS.app/Contents/Plugins/advanced-scene-switcher-old.so' not loaded
18:30:36.399: Failed to load 'en-US' text for module: 'decklink-ouput-ui.so'
18:30:36.596: os_dlopen(libpython3.7m.dylib->libpython3.7m.dylib): dlopen(libpython3.7m.dylib, 257): image not found
18:30:36.596:
18:30:36.596: [Python] Could not load library: libpython3.7m.dylib
18:30:37.848: No blackmagic support
18:30:38.495: [VideoToolbox encoder]: Adding VideoToolbox H264 encoders
18:30:39.656: [obs-browser]: Version 2.7.16
18:30:40.086: os_dlopen(/Applications/OBS.app/Contents/Plugins/obs-ndi.so->/Applications/OBS.app/Contents/Plugins/obs-ndi.so): dlopen(/Applications/OBS.app/Contents/Plugins/obs-ndi.so, 257): Library not loaded: @rpath/QtWidgets
18:30:40.086: Referenced from: /Applications/OBS.app/Contents/Plugins/obs-ndi.so
18:30:40.086: Reason: image not found
18:30:40.086:
18:30:40.086: Module '/Applications/OBS.app/Contents/Plugins/obs-ndi.so' not loaded
18:30:40.763: os_dlopen(/Applications/OBS.app/Contents/Plugins/spectralizer.so->/Applications/OBS.app/Contents/Plugins/spectralizer.so): dlopen(/Applications/OBS.app/Contents/Plugins/spectralizer.so, 257): Library not loaded: /usr/local/opt/fftw/lib/libfftw3.3.dylib
18:30:40.763: Referenced from: /Applications/OBS.app/Contents/Plugins/spectralizer.so
18:30:40.763: Reason: image not found
18:30:40.763:
18:30:40.763: Module '/Applications/OBS.app/Contents/Plugins/spectralizer.so' not loaded
18:30:40.919: os_dlopen(/Applications/OBS.app/Contents/Plugins/tuna.so->/Applications/OBS.app/Contents/Plugins/tuna.so): dlopen(/Applications/OBS.app/Contents/Plugins/tuna.so, 257): Library not loaded: /usr/local/opt/libmpdclient/lib/libmpdclient.2.dylib
18:30:40.919: Referenced from: /Applications/OBS.app/Contents/Plugins/tuna.so
18:30:40.919: Reason: image not found
18:30:40.919:
18:30:40.919: Module '/Applications/OBS.app/Contents/Plugins/tuna.so' not loaded
18:30:40.973: os_dlopen(/Applications/VLC.app/Contents/MacOS/lib/libvlccore.dylib->/Applications/VLC.app/Contents/MacOS/lib/libvlccore.dylib): dlopen(/Applications/VLC.app/Contents/MacOS/lib/libvlccore.dylib, 257): image not found
18:30:40.973:
18:30:40.974: Couldn't find VLC installation, VLC video source disabled
18:30:40.994: ---------------------------------
18:30:40.994: Loaded Modules:
18:30:40.994: vlc-video.so
18:30:40.994: text-freetype2.so
18:30:40.994: rtmp-services.so
18:30:40.994: obs-x264.so
18:30:40.994: obs-vst.so
18:30:40.994: obs-transitions.so
18:30:40.994: obs-outputs.so
18:30:40.994: obs-libfdk.so
18:30:40.994: obs-filters.so
18:30:40.994: obs-ffmpeg.so
18:30:40.994: obs-browser.so
18:30:40.994: mac-vth264.so
18:30:40.994: mac-syphon.so
18:30:40.994: mac-decklink.so
18:30:40.994: mac-capture.so
18:30:40.994: mac-avcapture.so
18:30:40.994: linux-jack.so
18:30:40.994: image-source.so
18:30:40.994: frontend-tools.so
18:30:40.994: decklink-ouput-ui.so
18:30:40.994: coreaudio-encoder.so
18:30:40.994: advanced-scene-switcher.so
18:30:40.995: os_dlopen(../obs-plugins/obs-browser->../obs-plugins/obs-browser.so): dlopen(../obs-plugins/obs-browser.so, 257): image not found
18:30:40.995:
18:30:41.050: ==== Startup complete ===============================================
18:30:44.427: Service '' not found
18:30:44.614: All scene data cleared
18:30:44.614: ------------------------------------------------
18:30:46.050: coreaudio: device 'Built-in Input' initialized
18:30:46.133: Switched to scene 'Scene'
18:30:46.149: ------------------------------------------------
18:30:46.149: Loaded scenes:
18:30:46.149: - scene 'Scene':
18:30:47.231: adding 162 milliseconds of audio buffering, total audio buffering is now 162 milliseconds (source: Mic/Aux)
18:30:47.231:
Most of your third party plugins is failing to load here, and OBS-NDI isn't even listed. Did you compile this version of OBS yourself? Did you install both the NDI runtime and the plugin?
I downloaded OBS directly from the website. I downloaded the NDI 4.7.1 + the 4.0+ Runtime.
I did notice this message containing the obs-ndi.so file but it stated it didn’t load. Do you know if NDI runs on OS X Sierra? I have seen other successfully running it on High Sierra, but I haven’t found an install to upgrade my OS X.
18:30:40.086:
NDI runs on Sierra.
Did you manually install the plugin?
It's supposed to be in:
/Library/Application Support/obs-studio/plugins
Not in the OBS.app bundle.
NDI runs on Sierra.
Oh i just noticed that. I looked in /Library/Application Support/obs-studio/plugins and it is in there as well. Should i delete the file from the OBS.app folder? Not sure why it is in both places.
Pretty sure it should not be in that folder, and that the installer doesn't put it there, which is why I asked about manual installation.
Oh. I didn't manually install NDI. I just ran the Installer and selected Macintosh HD for location.
I am having this exact same problem, i read through the tread but didnt see a solution. is there any updates on this??
