obs crashing after multistreaming with obs and tiktok live studio
soraelartista
hey! every new to this and also already a bit annoyed at having multiple days of technical difficulties, whether its iommu for valorant, rivatuner and msi afterburner not working (still working that out) or this now. i went live on tiktok live studio and set up aitum multistream for obs to stream from twitch n kick, hopefully yt if i can get this fixed, and kept crashing. thought it was because of enhanced encoding for twitch in obs settings, turned that off, fixed the multicanvas issue for aitum multistream in obs, and also found out that it coulda been bc i used game capture for marvel rivals instead of window capture. cool, all that was changed. today i do the same thing of going live in obs using multistream plugin from aitum, go live after leaving obs stream on for a few mins (10-15) to set up tiktok live studio. no game, just chillin shooting the shits and then after a while, pc screens freeze, no response, definite crash. difference from this and last is that i had my pc actually reboot itself saying "your pc ran into a problem" whereas this time it just froze with everything open still. i foudn in my obs crash logs what seems to be the problem but dont know what it means or how to fix. i cna upload all my previous logs as well from last crash to possibly narrow it down. idk if its the encoders im using, video settings, my RAM, whatever. please help ASAP!! thank you very much to anyone that does genuinely help.
If you have issues with a third party plugin you should contact its dev via the Discussion section on the particular plugins' page or wherever the dev have set for this.
Also, if a crash occurs OBS produce a crash report. If there's no crash report, then the crash is caused by a third party app, GPU driver or operating system. If you don't see OBS closing and you can keep interacting with it, then it's not a crash and most probably an issue within a third party plugin.
Please take a look at the pinned posts on this forum.
log reports from initial incident (5/25) and today (5/27) very unsure of which logs pertain to the particular crash so i apologize. please lmk if theres anything else to provide or how to narrow it down.
edit: realized timestamp for crash report thats attached is from before my obs even crashed. hopefully log reports somehow are helpful.
Tiny Tubular Task Thread crashed, I think that has something to do with the audio side of the encode?
Anyway, check/update all of your plugins but start with Atium & see if there's any improvement. Your version is really stale & there have been fixes in more recent releases.
22:45:07.528: [Aitum-Multistream] loaded version 1.0.8
Issues:
165HZ refresh rate
10-bit color on secondary monitor
Scene Collection is bugged Only (1) Display, Game or Window Capture per Scene to avoid interference.
Atium Vertical Scene Collection is bugged (same as above)
I'm stopping there, seen enough of that log (slop).....
