Question / Help OBS Is fine for the first few minutes? Huge FPS drop.
Pandurpz
Hello! I've had this problem with a few games, OBS will run perfectly fine for the first few minutes (30fps, no problem) then out of nowhere it drops, 15-20 FPS and I can't figure out why? Even when I quit streaming, if OBS is still open it'll pick the game up at low FPS as shown below in the picture, could anyone help me figure out what's causing this? I also posted the logs, I ended the stream almost right aways as I saw the FPS drop, maybe that was a mistake. If needed I can test stream again to get the FPS to drop and have longer logs?
  • 2019-03-15 13-48-12.txt
