Question / Help Razer ripsaw obs
im-death
Good evening, I have this problem with the playstation 4, the capture card ripsaw hd and the obs program.
Anyone can help me?
  • 2020-01-21 20-58-18.txt
That's a bad signal between your PS4 and ripsaw. Is this being represented in the passthrough as well?
Try lowering the playstation's resolution to 720p. Personally I've never had good luck trying to capture 1080p60 with the ripsaw.
I've had an issue similar to that before, but I can't recall if I had to swap out the HDMI cable (poor connection/internal break) or if it was when I had HDMI enabled on the PS4 and was trying to 'strip' it with a splitter device, and turning off HDMI in the PS4's system menu fixed it.
On a side note, you can also look up past issues with the AverMedia LiveGamer Extreme 2 to find other troubleshooting ideas if the above don't fix it; it's literally the same capture device, licensed and put into a Razer-branded case (they did the same thing with the original Ripsaw and AM LGX).
