Replay Source
Replay Source 1.8.1
Hi everyone,
I am new to this but looked through the discussion and can't find the answer. I am developing a hockey talkshow, and am trying to use OBS to show instant replays from games to go over the play with viewers. I have the attached set up. I can get the instant replay to come up well enough, but it only comes up if I am active on the game display, otherwise the replay comes up black. My goal here is to only bring up the replay and not the entire game, as a pop up over my main 'talkshow' scene, as I think Twitch/youtube would have issues with the game streaming at all times. Is there a way to have it draw the footage from the game, even if the game display is not the active screen on the stream? Any help would be greatly appreciated, thank you.
I am trying to setup 2 cameras to do slow motion replay for a golf simulator. I got it setup. It's a little finicky but it does work. My problem is that it hangs, crashes, freezes (whatever you want to call it) OBS studio. I have to kill OBS and open it again. Sometime it will work for 3 minutes before crashing sometimes 20 minutes. I think around 30 minutes is about as long as I've gotten it to run. I can't find any crash reports (not sure I know where to look). I do have the hand reports that windows generates (not sure they will be any help).
I do think this only happens when I have multiple cameras capturing replay but I'm not positive about that.
The feature is so useful. I use it even if with the limitation of having to restart OBS all the time.
When it freezes the last thing in the log it writes is "replay added" for one of the two sources but never the second. It's always between "adding" the first and second replay that it hangs.
20:39:11.266: [replay_source: 'Replay Source'] audio triggered
20:39:11.266: [replay_source: 'Replay Source 2'] audio triggered
20:39:12.474: [replay_source: 'Replay Source'] replay added of 2.49 seconds
20:39:12.491: [replay_source: 'Replay Source 2'] replay added of 2.50 seconds
20:39:32.736: [replay_source: 'Replay Source'] audio triggered
20:39:32.736: [replay_source: 'Replay Source 2'] audio triggered
20:39:33.940: [replay_source: 'Replay Source'] replay added of 2.50 seconds
20:39:33.958: [replay_source: 'Replay Source 2'] replay added of 2.49 seconds
20:40:11.806: [replay_source: 'Replay Source'] audio triggered
20:40:11.806: [replay_source: 'Replay Source 2'] audio triggered
20:40:13.007: [replay_source: 'Replay Source'] replay added of 2.50 seconds
20:40:13.025: [replay_source: 'Replay Source 2'] replay added of 2.50 seconds
20:40:38.346: [replay_source: 'Replay Source'] audio triggered
20:40:38.346: [replay_source: 'Replay Source 2'] audio triggered
20:40:39.557: [replay_source: 'Replay Source'] replay added of 2.50 seconds
20:40:39.575: [replay_source: 'Replay Source 2'] replay added of 2.49 seconds
20:41:07.087: [replay_source: 'Replay Source'] audio triggered
20:41:07.087: [replay_source: 'Replay Source 2'] audio triggered
20:41:08.290: [replay_source: 'Replay Source'] replay added of 2.50 seconds
20:42:43.202: ==== Shutting down ==================================================
Thanks for this great Plugin !
I have the same question / problem as member "Tero" on October 7th, 2020:
I already use OBS software in American Football and baseball games.
For this I need different replay lengths - depending on how long the play lasts - a predefined replay length (duration set for example 10sec) is not perfect for my purpose.
A hotkey would be perfect to start recording (for example just before the Center snaps the ball) and then press a key to stop it as well.
Is that already possible somehow?
Thanks for your answer
Any of you know why is all my saved replay files (to the PC not in the OBS during the stream) is full green when I play it? I have tried to play the AVI files with a lot of player but the result are the same.
Thanks in advance!
Thanks in advance!
Hi! it is the same issue We have, but only with elgato CAMLINK 4K source. These are some lines I have found in log:
20:14:10.897: [replay_source: 'Fuente Replay'] Load replay pressed
20:14:10.897: [replay_source: 'Fuente Replay'] replay added of 9.67 seconds
20:14:11.012: [replay_source: 'Fuente Replay'] Save replay pressed
20:14:11.019: [replay_source: 'Fuente Replay'] start saving '2021-05-11 20.14.11.avi'
20:14:23.686: Output 'replay_ffmpeg_output': stopping
20:14:23.686: Output 'replay_ffmpeg_output': Total frames output: 378
20:14:23.686: Output 'replay_ffmpeg_output': Total drawn frames: 380
20:14:23.752: [replay_source: 'Fuente Replay'] stopped saving
If I try to open the saved replay with Windows program, this is the error that appears: 0xc00d5212
Also the saved replay duration is longer than the replay duration shown in obs.
It could be anything related with codec for 4k or HD?
Thanks in advance!
Replay Source use x264 for encode.
Source 1080p working correct, but when use 4K resolution, i got some problem (OBS almost stop, CPU 100%).
On I7 6700, use replays from 3 source in 1080p25, in 1080p50 i got some problems time to time.
Thanks in advance!
I use Elgato Camlink 4K too. Maybe this is the problem?
Bom, ótimo plugin. Eu tento usar a fonte de replay porque é definitivamente o plugin que eu preciso, mas o que acontece é que eu posso fazê-lo funcionar muito bem com uma fonte de vídeo gravada, mas eu não posso fazê-lo funcionar com câmeras ao vivo. Tenho uma placa Blackmagic duo.
After update 27.1 OBS crashes while starting up
through testing, I've found out that REPLAY SOURCE is the problem
this was already described here in the forum today:
any help ?
thanks in advance !
