Shadertastic
Shadertastic 1.3.0
xurei updated Shadertastic with a new update entry:
Version 1.1.3
This version focused on stabilization and hunting small memory leaks.
Fixed​
  • Fixed sources shown twice in source parameter
  • Fixed minor memory leak in load_settings()
  • Fix memory leak in condition evaluation
  • Fixed memory leak in transition auto-reload (dev mode only)
  • Fixed commit number not showing in settings
Added​
  • Gaussian Blur filter: added sigma parameter to control the smoothness of the blur
  • Transition...
I am currently trying to implement a shader from Shadertoy (https://www.shadertoy.com/view/3ty3Dy) as a custom shader in shadertastic, however I am having great difficulty debugging due to the Shader error line numbers not corresponding correctly to the original HLSL code. How would you advise I debug my shader code for use with this? Is there a way to access the transpiled GLSL to try to figure out what actual line the error is coming from?
Version 1.3.0
Also named the "Obviously, Why did I never thought of this?" version.
Added​
  • Vignette v2 effect: add "Apply Vignetting in Alpha Channel" in options, custom positioning and size
  • Face tracking: added "Reset on face lost" option
  • Zoom to face effect: add smoothing and tilt compensation
  • Shake on sound effect: support negative zoom
  • Rainbow effect: added a visibility toggle prompt
  • Settings: Add "open" button in folders list
  • Filter auto rename: if the...
After I installed 1.3.0. I can start up OBS on my Mac OS 13. 7. 8. do one action then OBS shuts own. Your last version worked great though. Thanks....update: It might not be your plugin. I deleted and my OBS 32.2.2. Crashes after a few clicks. I will investigate. Thanks... update#2 It doesn't crash anymore, but when the Shadertastic settings window comes out it is minimized to a bar. When I try to resize it. The window folds back in then vanishes. Thanks, Frank
Crash report:
