Shutdown Plugin 0.3.0
I think this issue and it's comment addressed the same issue. Could you have a look at this?
Thanks, that solved it. For anyone trying to use this plugin with the Multi OBS Controller, this was how I got it working. Create a "Raw WS Request" and populate the fields with the following or something similar:
Request Type:
CallVendorRequest
RequestData:
  "vendorName": "obs-shutdown-plugin",
  "requestType": "shutdown",
  "requestData": {
    "reason": "asdfasdf asdfa",
    "support_url": "https://github.com/norihiro/obs-shutdown-plugin/issues"
Got it. tawmae on the streamer.bot discord helped me format things correctly. I was able to send a raw OBS JSON
Here's what it looks like
  "requestType": "CallVendorRequest",
  "requestData": {
    "requestData": {
      "reason": "requested by streamer.bot",
      "support_url": 'https://github.com/norihiro/obs-shutdown-plugin/issues',
      "force": true
  "requestData": {
    "requestData": {
      "force": true
Please do not set https://github.com/norihiro/obs-shutdown-plugin/issues to support_url but set a URL to streamer.bot.
OBS 31.1.1
The 'force' parameter is "True", but it has no effect!
Python:
import obsws_python
import sys
cl = obsws_python.ReqClient(host='localhost', port=4455)
cl.send('CallVendorRequest', {
    'vendorName': 'obs-shutdown-plugin',
    'requestType': 'shutdown',
    'requestData': {
        'reason': f'requested by {sys.argv[0]}',
        'support_url': 'https://github.com/norihiro/obs-shutdown-plugin/issues',
        'force': True,
Updated source code is ready. I'm debugging the new build flow for OBS Studio 31. Hopefully, I can release this weekend. (It is tough work to support all 3 platforms. For now, Linux and Windows versions look ok.)
norihiro updated Shutdown Plugin with a new update entry:
Shutdown Plugin 0.2.0
This is a major update release.
Change in 0.2.0
  • When shutdown is requested with force = true, this plugin will request to stop recording and streaming to avoid the confirmation dialog.
  • The setting ConfirmOnExit is not longer modified by this plugin.
  • Rebuild for OBS Studio 31.1.1 (Windows and Linux), 31.0.0 (macOS).
Limitations
  • If using remux, this plugin cannot...
Shutdown Plugin 0.2.1
This is a patch release.
Change in 0.2.1
  • Fixed OBS Studio is not shutdown even if force = true when the virtual camera or replay-buffer is active.
  • Added a new parameter exit_timeout to more strongly force OBS Studio to terminate.
Limitations
  • If using remux, this plugin cannot shutdown even if force is set true. Set [FONT=courier...[/LIST]
@norihiro​
your plugin is very useful! I am using OBS for 24/7 projects, however OBS need to be refreshed after 2 days and it is helpfull to shutdown it. Would be great to have restarting option
@norihiro​
AFAIK, restarting the software is tricky.
Instead, I'd like to suggest another program having infinite loop to start OBS.
For example, a shell script like below would work.
on macOS:
Bash:
#! /bin/bash
while true; do
  open -W /Applications/OBS.app
  sleep 10
done
For Linux:
Bash:
#! /bin/bash
while true; do
  obs
  sleep 10
done
Auto-start from Task Manager on Windows or Cron on Linux would be another option.
This is a major-change release.
Change in 0.3.0
  • Renamed the vendor name from obs-shutdown-plugin to shutdown-plugin.
  • Updated build flow based on my template.
  • Added build-time information (such as git-describe) in the log.
  • Removed depending on Qt::GuiPrivate.
Limitations
    Set exit_timeout to positive value.
