Skipped frames due to encoding lag
theXIMIK
Hello everyone, maybe someone can help, figure out why I have such a problem. I play the game World of Tanks, almost minimal settings. PC rtx 4060 processor ryzen 7 5700. Sometimes I also run a stream with OBS, the Tik Tok Live Sudio program with it there are much more drawdowns, without it it is a little better but they are still there and it is not very pleasant
Very minimal amount of encoding overload in the log you sent but either way, you are doing a lot so it is not surprising. If you lower your preset from P7 to P5 in both your regular OBS output settings and your vertical canvas plugin settings that should resolve it.
Unfortunately, I reset the statistics, in 3 hours of streaming there were about 5000 skips, but thanks, I'll try to change it to P5 and I'll tell you tomorrow
