Smart Replay Organizer
Smart Replay Organizer v2.9.3
SlonickLab
Member
SlonickLab submitted a new resource:
Smart Replay Organizer - Smart Replay Organizer. Works with Borderless modes and detects games.
Smart Replay Mover
An automatic clip organizer for OBS Studio
Files are automatically organized by game.
Smart Replay Mover is a Lua script for OBS Studio. It works on Windows and Linux with no extra software needed.
It detects your current game and moves files quickly to the correct folder.
DOWNLOAD LATEST VERSION...
This is such a good script, thank you! I have a suggestion, is it possible to add a notification for when replay buffer is turned off or turned on?
thanks for sharing this script with the obs community and you done a kicka ss job mate too. I ahvnt came across nay problems myself but your updates have been spot on and worth a 10 out of 10
just want to ask if its posable to do update for this script to make it compacable with Aitum Vertcail or Aiitum Suit ? if not would you do another scrtipt like this one for them
Good question! I’ve figured this out, unfortunately, Aitum Vertical uses its own replay system called “Backtrack,” which is completely separate from OBS’s main replay buffer. Backtrack doesn’t trigger the standard OBS events that my script responds to, so my script can only handle OBS’s main replays, not Backtrack clips. I can’t fix this with Lua scripts. Aitum needs to add support for standard OBS replay events to its plugin. However, your main OBS replay buffer still works perfectly with Aitum!
thanks for the information, sounds like it would need a team just like Aitum to do it and just another idea, what happens if you add hotkey future to the script to match the Vertical and Aitum suit hotkey so one key dos both
