SmartStart
SmartStart v-1.0.0
Running Win 10 64x. Script doesn't work with error message "cannot find files". Script was loaded in standard location with other scripts on 2 different computers with same result.
The following is the error message
Would be great if in addition to the program name, it would allow entry of a command line for specifying startup options, and a starting folder, similar to the way Windows allows one to create a shortcut.
Agreed, this would be great. I use Chrome apps that need command line arguments like this to run.
Would also be awesome if we could add .BAT files to run as well!
