Some of my settings are grayed out.
AidenSuzuno
Hello ! I do not know why when I use my OBS, my settings are almost all greyed out, even when I'm not streaming, recording or using my virtual camera. Can anyone help me please ?
You have active output. That's why settings options disabled (inactive/grayed out).
To get what kind of output is currently active in OBS you may try to make custom script and run it. The script will print to the log-file of OBS all possible outputs and its current states.
See for details (the script itself and brief info how to use it):
I don't know.
Better to ask in the thread of the plugin. Maybe there you will find your answer:
This is both filter and source, so it should has some settings somewhere. Log-file says that you have applied it (filter) to number of sources, like 'Vtube studio' (source itself), 'Source média 8', 'test' etc.
@FlowMacAwesome I think, you have much bigger problems:
02:09:47.458: Number of memory leaks: 43
Can you run OBS with the --safe-mode command line key (so it wouldn't load plugins)?
The message on the screenshot of the OBS Settings says:
"Twitch Enhanced Broadcasting is controlling some of your stream settings" (in case it cannot be read by screenreaders or seen in other way).
that means that you have enabled special mode of streaming to Twitch, thus some settings were disabled.
It is poorly documented in OBS ( here is what "info" will be shared with the service: https://obsproject.com/forum/threads/obs-studio-30-2-rc.176114/ ) and in Twitch itself ( basic info: https://help.twitch.tv/s/article/multiple-encodes?language=en_US and few general words in https://blog.twitch.tv/en/2024/01/08/introducing-the-enhanced-broadcasting-beta/ ).
In short - the "Twitch Enhanced Broadcasting" is transfer, from you to Twitch's servers, not just 1 but 4-5 streams of the same content but at different resolutions and frame rates (for example: 1920x1080@60 6000 Kbps + 1280x720@60 2500 Kbps + 820x480@30 1000 Kbps + 640x360@30 500 Kbps + 284x160@30 200 Kbps, in total = 6000+2500+1000+500+200 = 10200 Kbps instead of 6000 Kbps with regular broadcast). This requires 4 additional encoders running on your PC. Same task but when it running on server's side of the online service is named "transcoding". For example, YouTube do it for free, Twitch - for money. For compatibility and performance reasons most of the parameters for "Enhanced Broadcasting" cannot be adjusted by user. Thus, you either using "Enhanced" broadcasting (and controls almost nothing) or using regular one (but still should fit all your settings to requirements of the service).
Some feedback about the feature, here, on the forum: https://obsproject.com/forum/threads/possible-to-tweak-enhanced-broadcasting.178887/
To disable "Enhanced Broadcasting" go to main menu File > Settings > Stream and make unchecked the Enable Enhanced Broadcasting setting (the option available for Service = "Twitch")
Yeah nothing works transform is grayed out. You can't copy and paste anything You can't recreate anything without it being grayed out it's absolutely worthless.... This stuff should be so easy to duplicate stuff copy and paste stuff You can't do any of that I don't get it I just spent three hours trying to make a new profile and copy and and paste and make a new scene you can't do any of it It's worthless....
So you can't copy and paste the scene without it being linked First off that sucks so once you do that you start deleting things and trying to recreate them and then you can't recreate them because they're all grayed out you can't do anything with them It's worthless.
I just copy and pasted a scene and I'm trying to recreate a media segment of the scene and not have it linked to the other scenes and I can't do it there it's all grayed out it doesn't show up It's worthless I don't get it it should be something so simple and it doesn't work at all!!!!
