Tuna
Tuna v1.9.11
HELLO feeling very stupid and having trouble finding the right version and instructions for installing for UBUNTU 20.04.5.
Can anyone help - the Overview just says:
"Linux
If you use a Debian based distro you can use the installer, all other distros currently have to either build the plugin from source or extract the binaries from the debian installer and move them into the correct folders themselves."
Which is too vague for my abilities... help
Ok I've upgraded to UBUNTU Jelly Fish 22 and I've installed Gdebi and i've downloaded and
run sudo gdebi /root/Downloads/tuna-1.9.1linux-x86_64.deb
which seems to work but I dont see it in tools
Do I have to restart OBS?
Ideally I dont want to because Im streaming
If you had OBS open when you installed the plugin, you have to restart OBS.
Hey, definitely the tool I was looking for, but for some reason the textfile only conatins the placeholder. Won't update to any playing song. Since I'm new to this stuff , propably an Error on my side, but I have no clue which. Watched tutorials and followed your manual, but no results. Any ideas? Thx in advance
I have what is perhaps an unusual question: Is there a way to use more than one source simultaneously in Tuna, or perhaps run multiple instances of Tuna? Basically, I want to be able to use two separate text sources with song info from two music players - e.g., two different Spotify accounts, a Spotify account and VLC, etc. If it were possible, I'd be willing to run Tuna outside of OBS, as well.
EDIT: If it matters, this would be on Ubuntu 22.04.
Hi there, I seem to be having an issue where any placeholder image I try to make and point the program at seems to overwrite it with the generic placeholder image either immediately or whenever a song stops playing. Even saving over the image seems to do nothing so I'm curious if there's a setting I'm just not seeing or is there something I'm not doing right? I pull my information off of Spotify if that helps any!
You'll need to upload your obs studio log file. My guess is that Spotify is limiting the request rate.
No, unless you want to run two instances of obs studio.
That path is where tuna saves the cover of the currently playing song.
How do I change the placeholder?
The placeholder image is saved under C:\Program Files\obs-studio\data\obs-plugins\tuna\placeholder.png or ~/.config/obs-studio/plugins/tuna/data/placeholder.png. It can be replaced with a transparent png if you don't want anything to show when nothing is playing.
OH I completely misunderstood when I read through everything! Thank you so much for the clarification! Everything's working just fine now!
Could fix it. Had to enable the share what you listen to setting in spotify. Works perfectly now. So thx again for the great work and of course the support
I'm having installation issues, could anyone help?
step 1: I ran tuna-1.9.1-windows-x64-Installer.exe
2: After that, tuna.dll and tuna.pdb appeared in C/Program Files/obs-studio/obs-plugins/64bit, where it should be
3: turn PC off then back on
4: I should see a new option in the Tools menu, but it's not there!
I'm on OBS 27.2.4 (I rolled back to an old version when 28 broke most of my plugins)
Hello.
I am using Windows Media Control (Browser-YouTube).
Is it possible to add a variable to display the chapter titles of the video?
Thank you.
1.9.1 is for OBS v28 only.
