[Windows 11, Laptop] Window Capture issue with GGPoker
Questje
Hi all!
I have a recurring issue with OBS on Windows 11 using a Dell Laptop [1], capturing GGPoker. I use Window Capture to grab the different poker tables, and I've been doing this successfully for 3+ years now on the same device. Only recently, sometimes from the start, sometimes after streaming for a while, the capture fails, and I only see a black screen with a "disturbed" mouse cursor (see image below). Changing the capture to a different window (and back) doesn't solve it.
I have read the related post "Laptop? Black screen when capturing? Read here first." [2], and I've tried to set both OBS and GGPoker to use the same GPU. My Video Encoder is set to NVIDIA NVENC H.264. I've included my log file [3].
Things I've tried:
- If you want to use display capture to capture your screen / desktop, select "Power Saving". Tried this, but the same issue still happens sometimes.
- Using "Optimize graphics for games with windows" (normally disabled, enabling didn't solve it)
- Using OBS Game Capture: Works "ish" but it doesn't see differences in poker tables (even if they have clear different window titles), so it's not practical for me.
- Using OBS Display Capture: I don't want to use this, and it often doesn't "see" GGPoker (but captures everything else correctly).
- Often, restarting GGPoker solves the issue, but recently only temporarily. I can't put my finger on what triggers it to happen. It might switch which GPU it uses?
Not sure if this is related at all, but I've also noticed when I try to make a screenshot using the Windows Snipping Tool, I can't capture GG either. It minimizes automatically when starting a snip. It captures everything else fine.
I know my laptop is quite old, but streaming has been working fine for 3+ years, so I'm not going to upgrade just because of this issue :)
Any help would be greatly appreciated!
Greetz,
Questje / Twitch Poker Streamer
Sources/links:
[1] My Laptop (Intel Core/GeForce GTX 1050): https://tweakers.net/pricewatch/1612756/dell-inspiron-15-7590-bn75903/specificaties/
[2] OBS Forum post: https://obsproject.com/forum/threads/laptop-black-screen-when-capturing-read-here-first.5965/
[3] My OBS LOG: https://obsproject.com/logs/DerzjzCa5oYIBiG8 (I have removed the Multiple Game Capture sources already, so you can ignore that)
When trying some stuff out (Force SDR Yes/No, Capture Method Automatic etc) I saw these errors in the log:
19:37:15.951: CreateForWindow (0x80070057)
19:37:28.644: [window-capture: 'PokerTable2'] update settings:
19:37:28.644: executable: GGnet.exe
19:37:28.644: method selected: WGC
19:37:28.644: method chosen: WGC
19:37:28.644: force SDR: false
19:37:28.782: CreateForWindow (0x80070057)
19:37:36.543: [window-capture: 'PokerTable1'] update settings:
19:37:36.543: executable: GGnet.exe
19:37:36.543: method selected: WGC
19:37:36.543: method chosen: WGC
19:37:36.543: force SDR: false
The CreateForWindow lines are printed in red as well. Maybe this can help solve it?
(Nothing helped, just got the black screen and cursors)
Thanks for your reply.
Sadly, Display Capture doesn't work for me; when the Window Capture fails, the Display Capture fails in the same way (capturing everything except the poker tables). I seem to be one of the few poker streamers with this issue, so there must be something I can fix locally. Also, it's been fine for years, that's weird right? :)
Well, in the end, without other solid options, I re-installed GGPoker which magically solved the issue (for now).
My 8 hour stream went fine and the issue didn't reappear. But I'd rather know WHAT fixed it, so would still be nice to know haha :)
I'll report back if I find it out.
Hey Carlos, thanks for letting me know. I'm also very sceptical my solution will be "solid".
I need the "real" fix instead of reinstalling GG haha. Hope at least one of us finds out and posts here later :)
GL!
You most definitely ran into GGPoker's (Windows) anti-cheat and your tables were "hidden" from the capture software, in this case OBS. This is also why you couldn't make a screenshot of the tables with a different tool, and why restarting the client worked for a short while - until you got flagged again. Custom software to run bots or RTA tools utilize the same Windows Graphics Capture APIs as OBS, and this triggered the anti-cheat. So if it happens again, try asking GGPoker for support instead.
Reinstalling the poker client likely forced a new scan of your machine and removed any flags, but this is just an educated guess.
Thanks for your reply!
Never considered that. And I even asked about my issue in several GGPoker/Streamer communities, haha.
It makes a lot of sense, sadly no clue how we can prevent it from happening again. I'll ask around.
I'm obviously not using any RTA tools :)
Thanks!
Can't believe we're here again, but the issue came back. Only showing a mouse cursor and a black screen when trying to capture GG, see the image at the top of this thread.
What I did in the meantime:
- Bought a new PC, it's now a Desktop instead of a Laptop and works completely fine. OBS runs smoothly, etc.
- Asked GG if there could be an issue with my account or any flagging for RTA tools as Zeddicussami mentioned above, they confirmed my account isn't flagged or anything like that, but also had no real technical advice.
Since I'm only using one GPU for everything now (NVIDIA GeForce RTX 5060), it can't be the combination of using two GPUs in the wrong way as I had on my laptop.
The issue matches the situation where I try to make a screenshot - even if OBS isn't running - and it instantly minimizes the window, making a screenshot impossible. OBS seems to struggle with the same thing, in some way.
I'm again lost for solutions.
Any advice is appreciated.
I may have found the solution, but will report back after a full succesfull stream.
It might indeed have been GG killing the capture mode (including screenshots) as a malware/anti-cheat system. While I wasn't doing anything like that, I'm a coder and sometimes have Python running locally in VS Code haha. I was this week, hence the issue.
Fingers crossed we can close this topic soon if it stays okay now.
