Write with iPad on a "transparent background"
simon84
Hi all,
I want to use OBS on my MacBook M1 Pro. What I need is a transparent layer, where the notes from my iPad are visible (like in freeform or Goodnote).
How can I realize that? You can see an example in the attached file. This was made with Ecamm and I guess, that OBS should also be able to do so?
Thanks
Simon
I used ProCreate with a green background, and then Chroma Keyed it:
Thank you! I think, it is not about the app on the iPad, it is more about the layers in OBS.
I also could use Freeform with a green screen and chromakey - but my problem is: How to bring this transparent layer on the screen, where I am writing on? What exactly do I have to do? I don't get it till know.
Step-by-step:
1. On your iPad, create a background with green coloring;
2. On OBS, add a new [Video Capture Device] Source;
3. On OBS, select your iPad (and adjust dimensions / crop);
4. On OBS, right-click the [Video Capture Device] Source you just added and select [Filters];
5. On OBS, under [Effect Filters], add a new [Chroma Key] filter. No need to change anything. Just confirm all and close the [Filters] window;
6. On your iPad, go bonkers;
